Autocad lt 2010 on windows 11
dszymanczak
Observer Observer
dszymanczak
Observer
Observer
Has anyone tried to run Autocad 2010 on windows 11? Works well on W10. Installation was succuessfull, but can't run anything as I get Unhandled access violation writing. Tried a solution with Framework but nothing helped. Any ideas?
RobDraw
Even if it does work, you won't be able to get it activated.
Rob
rushabhthakkar_910
@dszymanczakWin11 is not a supported OS for your old software. Sorry.
Win10 might work, maybe (you'll need to downgrade, ask your laptop maker for help there).
Assuming you can get LT2010 to authorize, since Autodesk has sort of stopped making it easy to automatically do so since July of 2021.
Also Can you share the error of Unhandled Access Violation..??
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-....)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
dszymanczak
Observer
Observer
Thank You so much for Your answer. My only solution here seems to be buying W10 and installing it on my new PC. Gonna try with Framework once again, but only to ensure myself... The error is: unhandled access violation writing 0xfdcc1000 Exception at 632ae647h.
mdavis22569
@dszymanczak
As mentioned:
No it won't work on W11, nor W10
and they are no longer activating 2010 software.
Mike Davis
