AutoCAD LT 2009 Installer
Message 1 of 9
We are moving our copy of AutoCAD LT 2009 from an XP PC to a Windows 10 PC and we no longer have the install discs for it. From what I have seen, I need a temporary link to the installer? That would be most helpful or any other suggestion to get what I need.
Thank you.
Replies (8)
Message 2 of 9
Mark.Lancaster
@Anonymous
Welcome to the community..
The 2009 version is no longer supported and is retired.  There is no live download links for it.  However chat with an agent here and see if they will provide you access.
Also 2009 may not function properly or even work under Windows 10 so I'm not if you want to go that route.
Mark Lancaster
Message 3 of 9
Thank you! I will try that and thank you for the advice.
Message 4 of 9
natasha.l
Hello @Anonymous,
Yes, welcome. As mentioned download links are no longer available online to download. I have included a link for you to use, it will expire in 30days.
AutoCAD LT 2009 English WIN 64bit
http://efulfillment.autodesk.com/2009/ACDLT/AutoCAD_LT_2009_English_Win_64bit.exe?authparam=14860701...
AutoCAD LT 2009 English WIN 32bit
http://efulfillment.autodesk.com/2009/ACDLT/AutoCAD_LT_2009_English_Win_32bit.exe?authparam=14860704...
If my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Message 5 of 9
Hi, try downloading the autocad lt 2009 but I think they are already disabled, you can re-install them to download them, please.
regards
Message 6 of 9
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
regards
Your posting is not clear..  Not sure if you're trying to provide a solution or you have an issue..  Please clarify..
Mark Lancaster
Message 7 of 9
freese.christine
Community Visitor
Community Visitor
Hello!
Hope all is well!
My current employer would like me to use their AutoCAD LT 2009 for a small project.  Is there still a way we can install it?  By chance can you send me a new link?
Thank you so much!
Message 8 of 9
pendean
Community Legend
Community Legend
@freese.christine LT2009 is a dead product: your employer will need to provide you with it and with activation codes since Autodesk will not do that either.
Message 9 of 9
LIGATECH
My auto 2009 lt traditional Chinese 64-bit disc is damaged. I need to reinstall it now. Is there a download link? I have authorization. There is also an activation code that can be used for transfer. Thanks.
