AutoCAD 2016 setup file
I can't find the 2016 autoCAD install. I have a license, but I can't use the 2016 version because it can't download it.
HELP
Alfred.NESWADBA
if you have 2016 as active version (and it's not updated or you are not on subscription) then you should find it inside https://manage.autodesk.com
If you have an active subscription, then you have AutoCAD 2022 and 3 releases back in this portal, but 2016 is then out of your active licenses.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
I have a 2016 autocad activation code. I cannot define this Code to user. If I can install the autoCAD 2016 original setup file, I will write my code in the serial-code section and use it. That's how I did Revit 2016. Someone shared the Revit 2016 installer on the forum. Can you share the AutoCAD 2016 setup file with me?
Alfred.NESWADBA
An activation code is bound to a serial number and to specific hardware.
If you have a new computer or an updated operating system or some parts inside the computer changed, this code does not work, you need a new one.
Having an activation code does not mean you have a valid license.
Again, the download of the setup's can be found in https://manage.autodesk.com
You might also "ask" Autodesk AVA here: https://ava.autodesk.com
- alfred -
Alfred NESWADBA
