AutoCAD 2013 serial number and product key
Message 1 of 214
Good Day,
I am about to install AutoCAD 2013 x64 that came with my AutoDesk Product Design Suite Ultimate. I noticed that it is has its pwn installer, but is it part of the Suite?
Would I use the same serial number and the suite product key or same serial number and the AutoCAD product key for 2013?
Sean
Replies (213)
Message 181 of 214
natasha.l
Hello @Anonymous,
Welcome back!
If you have the product serial # for the suite that's what you would use. So use the serial number and product key for the Suite (not the individual product) to activate your products.
Just a note, please be aware that Autodesk products are sold through the Autodesk EStore or by locating an authorized Reseller.
Please be careful when purchasing Autodesk product from sources outside of our authorized resellers center on our website.
Thank you.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 182 of 214
sir please send me serial number and product key for 2013 auto cad
Message 183 of 214
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Did you read any of the replies here?  Again, this is a user forum. . We don't send other users serial #s.  They come directly from Autodesk when you properly obtain this version 4 or 5 years ago.  Where did you get this legacy/out-dated/no longer supported version?
Mark Lancaster
Message 184 of 214
natasha.l
Hello @Anonymous,
Sorry but Autodesk support the current version & 3 versions back, older unsupported versions can become unavailable at any time & may not function on a newer operating system. Please review the system requirements before attempting to download & install. Also, Autodesk products are sold through the Autodesk EStore or by locating an authorized Reseller.
You may have the information you need located in  C:\Users\user name\AppData\Local\Autodesk\(product info.html) it includes the request code, product key and serial #.
Or please contact Customer Care to see if your product is still available.
Message 185 of 214
Computer
Message 186 of 214
Mark.Lancaster
@Anonymous
@Anonymous wrote:
Computer
What does that even mean?  Did you post my mistake?
Mark Lancaster
Message 187 of 214
This is realy helpful! Thanks
Message 188 of 214
WHAT ARE THE SERIAL NUMBER FOR AUTOCAD 2013
Message 189 of 214
Mark.Lancaster
@Anonymous
Serial #s come from Autodesk when you properly obtained this product 5 years ago.  Where did you get your copy from?
Mark Lancaster
Message 190 of 214
beyangpeter
Community Visitor
Community Visitor
pls for the serial number autocad architecture 2013
Message 191 of 214
Mark.Lancaster
@beyangpeter
Did you read my reply before posting?  Users don't send other users serial #s.  Serial #s come from Autodesk when your properly obtain this product 5 years ago.
Mark Lancaster
Message 192 of 214
I install the autocad 2013 software but i have no serial no and product key for activate the programe
Message 193 of 214
leowarren34
Hi @Anonymous,
This is a user forum, as Mark has said above we do not send other users keys. Furthermore, AutoCAD 2013 is out of full support so unless you have a key you can't buy one from Autodesk. Instead, you will need to get a license for a newer version and install the relevant version.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 194 of 214
REQUIRED AUTO CAD 2013 ACTIVATION CODE
Message 195 of 214
pendean
Community Legend
Community Legend
@anchorageext123
 If you still can somehow you should be able to do it here https://ava.autodesk.com/modular/
or you can open a ticket with the Licensing support and confirm your options for sure here https://knowledge.autodesk.com/contact-support/installation-activation
Otherwise you are very much out of luck forever and ever.
Message 196 of 214
nazaman.1977
Community Visitor
Community Visitor
hola, alguien tiene el numero de serie de autocad 2013?
Message 198 of 214
krahman769
Community Visitor
Community Visitor
Sir I need serial and product key please confirm
Message 200 of 214
sureshkimidi97
Community Visitor
Community Visitor
i want 2013 autocad serial number
