- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
If anyone is still interested in migrating acad2000 to a 64 bit PC - I've had some success but not 100% there yet, the main problem is just the install.exe which was written in old 16 bit lingo, everything else appears as 32 bit. IN order to overcome this I first moved the whole acad2000 folder from program files and placed it into program files (x86) folder on my win 7 (64 bit) machine. When tried to run. It coughed up a ton of 'dll' missing type errors which I solved by taking the 'acad' folder from the original installation disk and moved it's contents to the c:/windows/system folder. The software now runs and loads correctly, and loads .DWG files no problem - That's as far as I have got so far. If anyone can help progress this further by using a slave machine and share results I'd be grateful, I don't have win 10 so can't check it out there. I'm sure there will be more to do to get this perfect.
