Activation code of 3ds max 2010
Hello Dear , serial number is :xxx-xxxxxxxx
Request code is :5H8R 69K9 DVFT 3Z3G 8UY1 P35E U46S UG9Z.
Kindly send me activation code.
Thank you.
Alexander.Rivilis
You can use http://register.autodesk.com/ or https://ava.autodesk.com/ for activate your copy of 3DS Max
Activate & Register Manually
Facebook | Twitter | LinkedIn
Expert Elite Member
send me the activation code please
DarrenP
you don’t get activations codes from here
Autodesk stopped providing activations codes  for 2010 & lower on August 31, 2019
there is a dedicated forum on this change here: https://forums.autodesk.com/t5/previous-version-support/bd-p/6051
DarrenP
tomalbarman440
Community Visitor
Community Visitor
