ACTIVATING INVENTOR OLD VERSION
Have an old version 2010 of Inventor Professional installed but can't get it to activate, is there a way to activate it?
Product: AutoCAD Inventor Professional Suite
2010
Serial number: xxx-xxxxxxxx
Product key: 462B1
Request code: JUVX S54X HC90 8TTV
R7JE G3TJ X8EU 2J5Z
mdavis22569
Unfortunately it's not possible anymore.
More about that can be found here:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
What about products that didn’t use the year as a version (for example, R10)?
All products using a non-year version scheme are included in the v2010 or earlier set of releases and can no longer be activated after August 31, 2019.
Mike Davis
not helpful
mdavis22569
Not sure you're going to find something helpful ..
2010 isn't available for activation.  You'll need to update / upgrade the software.
Mike Davis
if you don’t like it search the internet for solutions then
start here: https://forums.autodesk.com/t5/previous-version-support/bd-p/6051
RobDraw
Brilliant! That's where we are!
I wonder if the OP has read any of the other posts about the same topic.
Rob
pendean
Community Legend
Community Legend
@RobDraw The post was moved from another forum 🙂
