Use morph function
Use morph function
Use morph function
Hi
I have attatch an image to perform a job.
Might be it will done using morph function but how?
jon.hunwick
Hi.
Piro_man's solution is probably the best way to go about this. The tricky bit about using the morph tool would be to know what the original shape should look like.
My only comment would be the it is much more efficient to use a 'spring primitive' than to construct the basic surface.
Jon Hunwick
This is much relevant but there is also some gaps between these turns might be 1.5 mm, Anyway thanks for good effort Mr. piro_man.
