Unable to import DXF/DWG
nirmit.patelW2WNN
Message 1 of 9
nirmit.patelW2WNN
While we import DXF / DWG file That time error as a below.1.png2.png
Replies (8)
Message 2 of 9
prashant.gurav
Hi @nirmit.patelW2WNN,
Thank you for contacting Autodesk Community.
Have you installed a 30 day trail version of Autodesk ArtCAM Standard 2018 at your end?
It seems that the 30 day trail period for Autodesk ArtCAM Standard 2018 has been over and you have to activate/purchase the software to use it further by clicking on the Activate button.
Thanks for your time and cooperation. If the provided information is helpful to you, please be kind to press the Accept as Solution tab or Reply back to me and I will be happy to assist you further.
Kind regards,
Prashant.G
Message 3 of 9
nirmit.patelW2WNN
Sir, Artcam is not use by me, I temporary install it.
But the error was came in Power Shape.
Message 4 of 9
nirmit.patelW2WNN
Message 5 of 9
prashant.gurav
Thank you for your response.
Please use the procedure mentioned here in order to uninstall Autodesk ArtCAM from your computer.
Please confirm if the error/pop up's get resolved after uninstalling Autodesk ArtCAM.
If the error is reproducible after uninstalling ArtCAM, I request you to use Autodesk Screencast to create and share a screencast demonstrating the issue that you're describing using PowerSHAPE.
Kind regards,
Prashant.G
Message 6 of 9
nirmit.patelW2WNN
Dear Sir,
Art CAM was not remove from my PC, so I think I will remove Powershape and re-install it.
Thanks for support.
Message 7 of 9
prashant.gurav
Dear Sir,
Thanks for support.
Thanks for your response.
You must have uninstalled ArtCAM from your computer using the control panel only, but that will not remove all the registry entries taken place while installing Autodesk ArtCAM 2018.
Hence, It is always recommended to use the Clean uninstall procedure mentioned here in order to uninstall any Autodesk product. If you want to uninstall Autodesk PowerSHAPE also, please use the Clean uninstall procedure.
Thanks in advance for your time and cooperation.
Kind regards,
Prashant.G
Message 8 of 9
jitendra.chaudhari
Thank you for contacting Autodesk Community Forum..
There was some instances reported while importing the DXF and DWG files in Autodesk PowerShape 207 SP2 version and this instance was resolved with next update PowerShape 2017 SP3. Can you  please update to latest version of  Autodesk PowerShape 2017 SP6 or upraded version Autodesk PowerShape 2018 R2 (2018.1.1.18121) if you upgraded to 2018 series? You can download the latest version of Autodesk PowerShape 2017 and  2018 from Autodesk Desktop App or logging into Autodesk Account
If you still able to reproduce the above instance with Autodesk PowerShape 2017 SP6 or Autodesk PowerShape 2018 R2 version please refer the attached copy of PDF Copy of Article. Please follows steps as mentioned in attached PDF File-
Follow the steps below;
1. Install the Visual C++ Redistributable for Visual Studio 2012 Update 4 from here.
2. Restart Computer.
This is already verified by some of users of Autodesk PowerShape 2017 and resolved the above instance successfully. Please verify and confirm.
If the above suggested version resolves the above instance, can you please click on the button Accept As Solution from my post in this thread.
Thank you for your time and co-operation,
Jitendra Chaudhari.
Message 9 of 9
Yogesh.Mohite
Are you still facing this issue with latest PowerShape version?
If above given information by @jitendra.chaudhari was helpful, can you please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers.
Yogesh Mohite
