Seperating components from main assembly
rgkerkstra
rgkerkstra
A customer recently sent us the whole assembly file when all we needed to work on was an insert. There appears to be many ways to separate the components. Is there one quick easy way?
Select the component(s) --> Right-click --> Convert --> To Geometry
suryakant.nirala
Hi @rgkerkstra,
Thank you posting your query on Autodesk Community!
I would like to add little more on it.If you want to separate the solid part from an assembly model.
  • Right click on the existing assembly
or
  • In the solid tree explore you can select assembly model and right click on it.
Kindly refer the snapshots for your reference.
convert.jpgtree convert.jpgPlease accept the solution button if my post fully solves your issue or reply with additional details if the problem persists.
Suryakant Nirala
