RMS error Powershape
I got a RMS error when I open Powershape 2016 since one week
Someone could help me please?
Accepted solutions (3)
It's about you license, if you paid for it, I think there are two options:
- first, if you have a network license, check your internet connection
- second, if you have a dongle (USB key), check if it is plugged in
If there is all right, you should think about the tip wrote at the end of this message.
Mateusz
ewshp
RMS license (network license) can be a pain to debug depending on the network configuration of your company.
Reading your post, it seems it worked a week ago....did you made any modification to your computer in the mean time ? Some firewall may block request to the licence server.
Also make sure that the latest version of the RMS file containing your licence has been properly setup on the licence server as follows :
RMS License Manager Tool  > Remove all features > Add Feature > From a File > <your_rms_file>
As the error code displayed refers to : No license code is available for this feature on the specified host
Hope this helps.
Sam
Yogesh.Mohite
Hi @Anonymous
Error 1005 means that the application is unable to acquire a license; this happens usually because the server is not running, or cannot be seen across the network or 'The licensing system has no licensing resources that could satisfy the request'.Please check that you have renewed license properly.
Please use below given procedure to renew license file.
  • Close all applications running off the back of the license server
  • Open the license manager tool
  • Delete all licenses from the server
  • Stop the server
  • Delete "lservrc" from the installation tree - e.g. Drive:\Program Files\Delcam\Flex4004\sys\exec\lservrc
  • Re-start the server
  • Install the new license onto the server.
Note: License file feature are store on "lservrc", so deleting this file will delete all your old features.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Thank You.
Yogesh Mohite
Thank you for your answers,It works now.
It was a RMS License Manager Tool error. I didn't know that there were a server which manage the license and the problem come from him.
I restarted the License Server Service and that's ok now.
