I have been trying to find some good PDF documents that outline the list of commands and features in PowerShape so I can become more familiar with the interface. Do such documents exist? If so, where can I find them?
Solved by Jonathan.Artiss-DSI. Go to Solution.
Hello @Anonymous
I got the same problem few time ago. Those documents are provided from your seller, try contact them to get "pdf's".
If you can't contact your seller, you always can look on youtube "Autodesk manufaturing" page that haves some video tutorials
There is the anwser that i got on my request: https://forums.autodesk.com/t5/powershape-forum/powershape-2014-r2-tutorials-request/m-p/9079757#M2720
There are several options for getting started with PowerShape.
You can go through online videos or tutorials via YouTube or going through the tutorials here https://learn.manufacturing.autodesk.com/courses#powershape
You can also go through the help notes in PowerShape. Go to Help top right (?) Help > Go to the Getting started section.
Jonathan Artiss
Senior Applications Engineer | DSI
