We want to ask how to change default color for a surface in PowerSHAPE? Like the image attached here.
My color scheme option is "black_on_gray" , and the default color for surface is blue.
We want to know, does it is possible change default color for a surface?
For ex. > standard21 or other (Topic Toolbar > Format > Material > Standard > standard21 )
Nathan.
Solved by jitendra.chaudhari. Go to Solution.
Hi @Anonymous ,
Welcome to Autodesk PowerShape Forum..
For changing the colour of the every new surface to be created, you would have to modify the existing colourscheme that is used by Autodesk PowerShape & for further details please refer the following procedure -
Thanks and Regards,
can this be added to the options so as to make it easier to do?
not sure why but it isn't working for me in 2018
i use the white on black like Nathan,
i changed the 1st 2 lines
material surface_white: \
colour: 255 255 255 \
group_name: Defaults \
transmission: 0.0 \
polish: 6.0 \
emission: 0.0 \
reflect: 0.5 \
shader_reflectance: "shader reflectance conductor {0.200 0.700 0.300 0.500 0.100 1.253 0.854 0.630 3.503 4.744 4.196}" \
override: true
this is not working for me??????????
Hi @a1moldmaker,
Thanks for contacting the Autodesk Community Forum.
I am not able to reproduce the above reported instance at my end in Autodesk PowerShape 2018. Please refer the screen-cast for further details-
Can you please explain in details regarding setting the default color for surface In Autodesk PowerShape 2018 ? Can you please confirm the exact variant (Standard / Premium / Ultimate)of Autodesk PowerShape 2018 with which you facing the above reported instance?
Please update if you are using any regional settings other than that of English. It would be great if you can record a small video showing the exact steps to reproduce the instance at our end?
Can you please confirm that you are modifying the correct color scheme and from Autodesk PowerShape 2018 installation at your end?
Please verify and confirm.
thanks,
that was what i needed
