Is it still possible to download the Powershape 2016 Tutorials, if so, is there an active link?
The tutorials linked on the website are for 2017 onwards.
Solved by jitendra.chaudhari. Go to Solution.
Hi @Anonymous,
Thank you for contacting Autodesk Community Forum..
I have uploaded the PowerShape training data and you can download it from following link-
https://autodesk.box.com/s/q7fy9udrrw09mbm9fv59rke6avcjaaaj
It have been noticed that some box links does not work if directly open in new tab. You can copy this link in new tab and download the data. I have informed box.com support about this issue and links will work directly as soon as possible..
If the above supplied data resolves your query then, please click on 'Accept as Solution' button .
Thank you for your time and co-operation,
Thank you for the link.
I noticed that when you click the link a few extra characters are added in the title box.. by deleteing these characters the link then works.
Hi Jitendra Chaudhari,
Thanks for the Powershape 2016 tutorials, that's really useful for me.
Could you also provide the PowerMill 2016 tutorials in a similar way?
Best regards,
Luk
Hi @Anonymous,
I have uploaded the Training data for PowerMill and you can download it from link -
https://1drv.ms/u/s!AhDFdOdG9otYgqs3Ivb9MMa4jMP6jw
If the above procedure resolves the instance, please click on 'Accept as Solution' button from my forum post in this thread.
hi this link isn't working for me could you re direct me to them thank you
Hi @jitendra.chaudhari & @Anonymous
Could you please reupload PowerShape 2016 tutorial file on OneDrive or on relevant cloud platform. Your efforts would be highly appreciated.
Regards
Please update a new link for the 2016 tutorials.
Dan
