PowerShape Forum
Welcome to Autodesk’s PowerShape Forums. Share your knowledge, ask questions, and explore popular PowerShape topics.
naming solids with macro
4 REPLIES 4
a1moldmaker
1492 Views, 4 Replies
is there a way using a macro to name a solid and if that name is used it will add a _next number
from a macro  if i create a solid block, name it base
them make another solid and name it base it would add _1 to second block
Bruce Green
Saying I cant always leads to failure
Saying I tried MIGHT lead to success
4 REPLIES 4
jon.hunwick
in reply to: a1moldmaker
That should be fairly easy, Bruce. In broad brush strokes (you will find the actual commands to use in the Help) what you'll need to do is this:
1 - Ask the user for a text string of the root name.
2 - Store the name of the currently selected solid
3 - Create a next text string that is the toot name + '_' + a number (starting at 1)
(The command you need here is 'concatenate' e.g. let newname = concatenate ($rootname ; '_' ; $counter)
4 - Find out if that solid exists.
5 - If it does not, rename the current solid
6 - If it exists, increment the counter by one, and go back to step 3
Jon Hunwick
camgank
in reply to: jon.hunwick
can you give me the example please
~try and pray~
Cadcam programmer
Mold designer
mwsiviero
Does anybody have an example, please?
mwsiviero
Does anybody have an example, please? Thanks.
Technology Administrators
