PowerShape Forum
Welcome to Autodesk’s PowerShape Forums. Share your knowledge, ask questions, and explore popular PowerShape topics.
Macro Programming Guide
2 REPLIES 2
glen_h
1253 Views, 2 Replies
I am wondering if there is a macro programming guide available similar to the one for Powermill?
We do a lot of repetitive operations in Powershape such as moving or rotating the currently active workplane or composite curve, etc.
I would like to incorporate macros to handle this, however just recording a macro results in a lot of selection and pick information inside the resulting macro code.
Instead I would like to command the macro to "move" the "currently active" workplane a certain amount in X or Y or Z just as an example.
There are many repetitive items that I need to address, so hopefully there is some source somewhere so I can learn the macro coding required.
Glen
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
2 REPLIES 2
kmarkopouliotis
in reply to: glen_h
attached file is all i managed to find.
Hope it's going to help you.
glen_h
in reply to: kmarkopouliotis
@kmarkopouliotis
Thank you!
