I had a problem when import and export DWG in Autodesk PowerShape Standart 2017 sp 5.Do you can help me for this problem?
Solved by jitendra.chaudhari. Go to Solution.
Hi @madaAG8FC,
Thanks for contacting Autodesk Community Forum..
I am not sure about this functionality but it seems the DXF and other third party file format import and export options is available with Autodesk PowerShape Premium and Autodesk PowerShape Ultimate version only.. Still I will ask development for this query and get back to you as soon as possible..
I will update this thread once I would get feedback from development on this query..
Thank for your time and co-operation,
Best Regards,
Hi @madaAG8FC,
Sorry but Please ignore my last log on this thread. I have found an internal document for this query.
It seems that you might have installed PowerShape SP5 (or nay service pack SP1 to SP5) directly without installing PowerShape-2017SP0. Just installing a service pack for PowerShape (SP..) will not install any licenses.
Steps for resolving DXF import / export query with PS Standard:
Please uninstall the previously installed PowerShape Standard 2017 then We must first install 2017 SP0 followed by 2017 latest Service Pack.
The significance of installing 2017 SP0 is that it also installs all the required licences including that of Exchange.
Development have just tested this and the behaviour they have observed is as expected:
1. Please install fresh copy of PowerShape Standard 2017 SP0 (CR 17136)
Please verify that you can export / import dxf file without any problems with this version.
2. Further please install PowerShape 2017 SP5 (CR 17144) or whichever is the latest.
Please verify that you can export / import dxf file without any problems with this version PS 2017 SP5 Standard.
Hope this resolves the above reported query.
Please verify and confirm.
Thanks and Best Regards,
I have to install PowerSHAPE 2017 SP0 first, then I install sp 6(not sp5)...
Hi @madaAG8FC,
Thanks for contacting the Autodesk Community Forum..
In that case can you please raise a case for this query from your Autodesk Account or contact your local re-seller so that they can create a case on behalf of you. So that we can pass this query to PowerShape development team for further investigation.
Thank you for your time and co-operation,
Best Regards,
I think you may be trying to do this the wrong way.
Try exiting drafting mode and return to modelling mode, highlight the wire frames that you want in you DXF then File-Export.
select the required options and hey presto !!
Hope that helps
Chris
I've tried to do what you recommend, but I can not. Does this affect the window that we use?
Hi @madaAG8FC
Sorry I forgot to add that I have added the above instance in change request to PowerShape development team. I don't think windows might have some role here. Still can you please confirm the exact windows version that you currently using?
Hi @ChrisDPCnc and @madaAG8FC
Can you please do some test at follows : (As asked by PowerShape development department)
[1]: When you launch Exchange 2017 standalone, what does it startup as - is it Standard or Premium
[2]: Are you able to import dxf files in standalone Exchange. please send me the log report. You can see the log report via the menu option 'Tools | View Translation Details'
[3] Please send me a screen shot of entries from add/remove programs. I would like to see entries of the form:
Autodesk*2017 FCS Licence
where * is the product name.
STANDARD
when i import file dxf file, file format can not running...
Please advice...
Mada Kharisma
i had a new update for this problem.
1.another workstation : Running Well with PowerSHAPE 2017 , Window 7 SP 1
2.workstation customer(The previous error) : If i install exchange 2016 R2 and than install PowerSHAPE 2017.Import/export DXF can running well.(Window 7 SP 1)
Hi @madaAG8FC,
Thanks for contacting Autodesk Community Forum ..
Can you please explain in bit more details regarding your comments as below?
1.another workstation : Running Well with PowerSHAPE 2017 , Window 7 SP 1 --> Can you please explain in more details? Does system have same Exchange Standard and able to export DXF ? Please confirm licensed version of the AMDEU installed on this system.
2.workstation customer(The previous error) : If i install exchange 2016 R2 and than install PowerSHAPE 2017.Import/export DXF can running well.(Window 7 SP 1) --> Can you please confirm that once again that does this system have same Exchange Standard and able to export DXF ? Please confirm licensed version of the AMDEU installed on this system.
Please verify and confirm..
Thank you for your time and co-operation.
