How to set the center of rotation in object...
I have a problem in object rotation in power shape 2018. 2017 version working correctly. How to set the center of rotation in object... what is the fault in Powershape 2018 below Screencast.
suryakant.nirala
Hi @Anonymous
Thank your placing your query on Autodesk Community!
It seems that you are facing difficulty while rotating the object from view rotate .You can lock the rotating centre as well as you can change the option for rotation around with tracing ball.
Kindly refer the attached snapshots for your reference.
Hope it will help you to get overcome from your concern.
Please accept the solution button if my post fully solves your issue or reply with additional details if the problem persists.
Suryakant Nirala
Sudhira
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for posting in Autodesk Community!!!
As I have seen your query regrading the rotation of CAD part not orient correctly. Please have a look on the attached snapshot by which i have highlight few option to modify  and get the right solution. It could be better to check whether your PowerShape update with latest service pack or not. If my post answers your query, please click on 'Accept as Solution' button.
Sudhira Dora
