How to make Rough surface models....
How to make Rough surface models in powershape... Attached rough surface model for your reference...
carlo.ferrario
Well done ! Impressive and high quality 3D
Is that possible sharing also process you used , could be interesting for the community
Tks so much for your job here and the impressive result
Carlo Ferrario
WWFO-CSO Post Sales Manager EMEA SOUTH
jonathan.artiss
Hi @Anonymous
Do you have access to ArtCAM or any other "artistic" software?
What I would recommend is that you find or create an STL mesh with the desired texture, then use the solid wrap tool to create the surface texture to your model.
If you don't have access to other software, you could probably find some textures online that you could use.
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
Thank you for your reply... i have artcam, but i don't know  how to make textures effect STL mesh.
jonathan.artiss
Hi @Anonymous
Have a look here at this short video on how to create a texture in ArtCAM, save as an STL and wrap  it onto a solid in PowerShape.
Cheers,
Jonathan Artiss
