dynamic mouse drag
dynamic mouse drag
apritchard
dynamic mouse drag
apritchard
I used to be able to hold the l/h mose button whilst hovering over an item. It now appears not to work. Is there a toggle switch somewhere which may have disabled it?
ChristopherMarion
hi @apritchard
Are you referring to the model drag tool with the left mouse button in PowerShape?
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
apritchard
Yes, ctrl key and mouse l/h button. Seems to have stpped working for me.
ChristopherMarion
Hi @apritchard
There are (2) ways to disable this feature.
One is in the PowerShape options.  If you access the options and go to the General>Mouse settings, you will see a n option for "Drag Move".  Reenable this if it is off.
The other option is to RMB in the graphics window (not on the model) and re-activate the option there.
Keep in mind, is you turn it off in the options area, it will show up disabled in the RMB menu.
Hope this helps!
Christopher Marion
SolidCAD - Canada
apritchard
thank you so much!
ChristopherMarion
Hi @apritchard
Do you mind adding a solution since others may inquire about the same issue?
Christopher Marion
SolidCAD - Canada
