PowerShape Forum
Welcome to Autodesk’s PowerShape Forums. Share your knowledge, ask questions, and explore popular PowerShape topics.
divide. split .Explode
11 REPLIES 11
Message 1 of 12
PLAS1991
1031 Views, 11 Replies
Hi
How can I divide the surface to multiple surfaces .
A simple example in attachments
Thank you
11 REPLIES 11
Message 2 of 12
in reply to: PLAS1991
Will be better if you do it on your own, I can tell you how to do this, but, try do it by yourself.
Here is my solution:
1) Select the surface and click "uncut" (Red box on screenshot "1.png")
2) Create new lines in the middle of each part of surface, and cut it (screenshot "2.png")
3) Select part of surface again, and cut it back (screenshot "3.png")
4) Blank the radious surface, create composite curve on each part of left surface, select composite curve and create new surface (screenshot "4.png")
I hope it helps.
Mateusz
_________________________________________________
edit:
Because I can attach only three files below are links to all of screen shots:
1) https://zapodaj.net/images/6b879aaa69beb.png
2) https://zapodaj.net/images/5a0743ed4785b.png
3) https://zapodaj.net/images/6ed981069ddce.png
4) https://zapodaj.net/images/594774fe53e88.png
Message 3 of 12
jon.hunwick
There is a much faster way to do this.
1 - Select all the surfaces
2 - Convert the surfaces to solid(s)
3 - Select all 4 solids, and convert back to surfaces
http://autode.sk/2cMUHEt
Jon Hunwick
Message 4 of 12
jon.hunwick
in reply to: jon.hunwick
Hi @PLAS1991
If you're happy with the solution, could you please mark this post as 'accepted'?
Jon Hunwick
Message 5 of 12
PLAS1991
Thank you for the quick reply
Not happy, We are now in Powershape 2017 And there is no Command Divide surfaces Push of a button without having to convert to Surface , Solid , Surface .
Autodesk must develop powershape In earnest and fast ,
And ending delcam ideas.
Thank you.
Message 6 of 12
jon.hunwick
If you would rather do it just with surfaces, try this (although unlike the solid method you will need to repeat for each separate surface).
1 - Select the surface and (if it's a NURB) convert it to PowerSurface
2 - Turn trimming off (so that you can see the surface edges)
3 - Use Ctrl/drag to add new curve(s) to the surface
4 - Select the new curve(s)
5 - Divide the surface
6 - Turn trimming back on
Again, a short video to show this is done.
Jon Hunwick
Message 7 of 12
So finaly you just copy my solution...
Only difference is, that I suggest to "Add curve" by surface feature from the button on the Surface Toolbar, You did it using CTRL and drag. Final effect is the same, and if your solution is a little bit faster, my is more precise.
Mateusz
Message 8 of 12
PLAS1991
Yes, but this is simple and easy Example 😏
I can divide the surfaces of the push button Other program 😌 It must be added in the future in Powershape.
thank you.
Message 9 of 12
jon.hunwick
If you could provide details of how this other software does it, we can add it to the development wish list.
Jon Hunwick
Message 10 of 12
thomas.brandt
Maybe this button   Break.JPG"Break surface" would serve as "divide surface"  which makes the function already available in PS
not as fast and easy as using the solid - divide solid route, but at the end you end up with eigth surfaces and not the "fillet" being broken into
multiple pieces of surfaces by solid divide, attached a two images
Message 11 of 12
PLAS1991
Dear Mr jon.hunwick
I look forward to hearing from you.
I recorded a video and put in attachments ,You can watch.
I have many ideas to help develop Powershape For the better and faster
Yours sincerely .
Message 12 of 12
jon.hunwick
Thank you
I will pass this on to development.
Jon Hunwick
