Hi guys.
We can define the file folder paths by ourself to find files we need quickly in PowerMILL.
(Just like the following picture)
Now I'd like to do the same thing in PowerSHAPE.
Do you know how can I do?
I have tried to define the model path where I found in the Customise Paths,and it does work when I choose "Open>Model" or "Save".
(Just like the following pictures)
However,when I choose "Import",it would not show the path I defined.
Is there any other way I can try?
Best Regards,
Chia
Solved by Jonathan.Artiss-DSI. Go to Solution.
@Anonymous
PowerShape is different from PowerMill and doesn't have a quick access button's for folder 1 and folder 2 user defined locations.
You can use the Windows "Quick access" in PowerShape
Add the folder location to the "Windows File Explorer" and it will populate in the PowerShape "Quick Access"
Right click on the folder and choose "Pin to quick access"
Jonathan Artiss
Senior Applications Engineer | DSI
Hi @Jonathan.Artiss-DSI
Thanks for your reply.
This way is useful,thank you very much!
Best Regards,
Chia
