Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Aligned Workplane macro
john_lute
john_lute
CREATE WORKPLANE NORMALSINGLE
Macro Pause " Pick Surface"
VIEW EDIT TOP
ZOOM FULL
ACCEPT
In powermill I can include the command Macro Pause "" so the user can place the work plane on a specific surface before the remaining macro continues. I'm going to put Macro Pause in the example. What command would I use for Powershape.
Is their a macro command that will complete the process and skip the edit option. So when the surface is selected and the workplane is positioned, the command stops.
ChristopherMarion
Hi @john_lute
I haven't done a lot of PowerShape macro's, but if you put in the command...... "input free" it will behave the same as a Macro Pause in PowerMill.  I just don't think you can put any instructions after the pause like you can in PowerMill.
Also, here is a link to the PowerShape macro writing guide.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Felipe_Callegario
This macro I use a lot, is it possible to use the work plan at the top, after aligning the model, I would like help with this solution, @Anonymous
