PowerShape and PowerMill API 2018 compatibility
paolo_lamperti
Autodesk Support Autodesk Support
Message 1 of 10
paolo_lamperti
Autodesk Support
Autodesk Support
Hi guys ,
I have created a embedded app using PowerShape and PowerMill API .
This app embed Powershape UI in my form .
Now with 2018 versions , PowerShape and PowerMill API starts PS 2018 releases .
is there a way to say start only 2017 version of PowerSHAPE ?
are PowerShape and PowerMill API fully compatible with 2018 ?
thanks
regards
paolo
src=“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png” >
Paolo Lamperti , Technical Support Specialist, Advanced Manufacturing WWFO-CSO, Global Product Support
Replies (9)
Message 2 of 10
luke.edwards.autodesk
You can specify the version to attach to when creating the connection.  The constructor for PSAutomation and PMAutomation both take a version number as a parameter.
Luke Edwards
Consulting Services Manager
Message 3 of 10
paolo_lamperti
Autodesk Support
Autodesk Support
Thanks for the answer
I saw the parameters , but I haven't clear the format of the parameters .
They are from Version class , but if I say
// for PMILL 2017
 Version vs= new Version(21, 0, 30);
 var powermill = new PMAutomation(InstanceReuse.UseExistingInstance, vs);
Visual Studio 2015 raise the exception that there is no PowerMILL of such version .
please could you give an example on how to set specific version start-up ?
thanks
regards
paolo
Message 4 of 10
What happens when you type in "PRINT PAR 'version' into PowerMILL 2017?
odd, under help>>about my 2017 is version says "21.0.30.64.1203039" but when i type that command into the command window it returns "21.000".
With 2018 installed, i can confirm this launches a new session and makes a tool as instructed:
            Version vs = new Version(2018, 0, 0, 1212103);
            PMAutomation powerMILL = new PMAutomation(Autodesk.ProductInterface.InstanceReuse.CreateNewInstance, vs);
            PMProject pmProject = powerMILL.ActiveProject;
            //do stuff with the project
            PMTool newBallnose = pmProject.Tools.CreateBallNosedTool();
            newBallnose.Diameter = 12.7;
            newBallnose.Length = 101.6;
So now we just need to figure out the correct version to use for 2017, assuming all service packs are installed.
Also, something seems strange with 2017's version number. There are 5 parameters, but i believe there should only be 4: major, minor, build, and revision.
Message 5 of 10
Paolo
Please ensure you are running the application in x64 build mode.
Luke Edwards
Message 6 of 10
Using Luke's suggestion the following should do what you want:
            Version vs2017 = Version.Parse("21.0.30");
            PMAutomation powerMILL = new PMAutomation(Autodesk.ProductInterface.InstanceReuse.CreateNewInstance, vs2017, vs2017);
Message 7 of 10
paolo_lamperti
Autodesk Support
Autodesk Support
Hi guys ,
I have some issues this time starting PowerSHAPE 2017 , using these lines :
 Version ps2017 = Version.Parse("17.1.36");
 PSAutomation powerSHAPE = new PSAutomation(InstanceReuse.CreateNewInstance, ps2017, ps2017);
PowerSHAPE doesn't start correctly
please see the attached image from Visual Studio 2015 .
do you have any ideas about ?
after some time PowerSHAPE starts then closes ...
thanks
regards
paolo
Message 8 of 10
Is there any more code below that line? Strange that it closes after launching.
Message 9 of 10
Try version 17.1.45.
I just did this to verify the version:
            PSAutomation powerSHAPE = new PSAutomation(Autodesk.ProductInterface.InstanceReuse.UseExistingInstance);
            MessageBox.Show(powerSHAPE.Version.ToString());
It returned 17.1.45. Strange since Help>>About shows 17.1.36.
Message 10 of 10
paolo_lamperti
Autodesk Support
Autodesk Support
Hi guys,
yes strange that the version from Help is different from print version in PSHAPE .
I just wrote those two lines of code , as you did .
If you look at the picture attached , something strange happens while the API is searching PSHAPE 2018 probably in the registry .
Second problem :
powerSHAPE.IsGUIVisible = false;
doens't disable the Ribbon upper interface in PSHAPE 2018 ...
thanks for your help !!
ciao
paolo
