how to create program to control robot plugin
chenzhaoxiang2013
Message 1 of 8
chenzhaoxiang2013
hello,
currently, i am following the user guide of Powermill API and trying create program in Visual Studio with c#. I am attempting to create a command to control the robot plugin (robot program) to generate the .LS toolpath file. does anyone know the tips for creating the program to use robot plugin in Powermill?
Replies (7)
Message 2 of 8
VitorMartinsAugusto
You cannot control PRI as it is a plugin itself.
However, you can use the different specific PowerMILL commands that PRI uses.
Use the PowerMILL console to see what commands PRI is launching.
Message 3 of 8
chenzhaoxiang2013
hello vma,
thank you for your reply.
could you interpret more details about how to use the PowerMILL console to see what commands PRI is launching?
do you mean by checking the Macro echo command in powermill?
Message 4 of 8
VitorMartinsAugusto
Yes, you use ECHO COMMAND and then use a function of PRI. The relevant commands will be listed in the console.
You then need to try to understand what each command does...
Vitor
Message 5 of 8
chenzhaoxiang2013
hello Vitor,
not all function of PRI can correspond to a valid ECHO COMMAND, for instance, for 'robot program' plugin, the corresponding ECHO COMMAND does not work properly.
Message 6 of 8
VitorMartinsAugusto
Of course, PRI has its own algorithms, which do not correspond to plain PM commands.
You won't have access to those...
Your only way is to reprogram those algorithms yourself (lots of work, I know). But at least in theory it is possible to do everything that PRI does from your own application - you have access to the same core PM commands.
Vitor
Message 7 of 8
chenzhaoxiang2013
indeed, that is lots of work to reprogram those algorithms.
however, in the reference 'autodesk.prodectinterface.powermill' of visual studio, there exists many commands to access the parameters and functions of powermill. is it possible to access the plugin as well? or if there is any reference (.dll file) helpful with that?
Message 8 of 8
VitorMartinsAugusto
That is not possible.
Think of it like that:
POWERMILL <- OLE -> PLUGIN
PLUGIN is what YOU are programming. You get access to PowerMILL's function set.
In case of PRI, PRI is the plugin!
You cannot do this:
POWERMILL <- OLE -> PRI <-> PLUGIN
Why? Because PRI is itself a plugin and it does not offer any further interface to other applications to attach to it.
If you do a simple plugin, other programmers won't have access to your functions, either, unless you program a specific interface.
Hope this clears this up.
Vitor
