how can i run macro applying another button into vb.net
Message 1 of 12
help, please
I have one botton1 to connect the powershape and then I want to run the new macro into the new botton2 without open again
the powershape. I want to work wiht the same file active (botton1)
How can I do this?
I am working in visual studio 2013, language visual basic.Net
i am using windoes forms
I have powershape and powermill 2018
Excuseme my english is not very well. Iam Mexican and want to implement the automation of
powershape and powermill in my work.
Can you give me a tutorial or manually
thanks for you help
ATTE:
Damian Hernandez
Replies (11)
Message 2 of 12
rafael.sansao
Paste on button 2:
Dim powerSHAPE As New PSAutomation(Autodesk.ProductInterface.Instance.UseExistingInstance)
Dim m as string = "MACRO RUN 'c:\macro.mac'"
powerSHAPE.Execute(m)
or
Dim m as string = "c:\macro.mac"
powerSHAPE.MacroRun(m)
I do not know if the syntax is correct. I use C#.
Documentation:
https://forums.autodesk.com/t5/powershape-and-powermill-api/getting-started-with-powershape-and-powe...
Rafael Sansão
OptiNC - www.optinc.tech
Message 3 of 12
luke.edwards.autodesk
The best solution is to connect to powershape in Button1. Declare the variable of powershape in the scope of the class rather than the method. Then you can just use that instance in Button2. The alternative method posted would work but would have an overhead with connecting twice.
Luke Edwards
Consulting Services Manager
Message 4 of 12
Ok, Thanks
but, It doesn't work
Message 5 of 12
Good day luke, thanks for answering
One Question:
How Can I create a new instance for the button 2?
Can you help me?
add my program here:
Imports Autodesk.ProductInterface.PowerSHAPE
Imports System.Windows.Forms
Imports Autodesk.Geometry
Imports Autodesk.FileSystem
Public Class Form1
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
'ACTIVAR powerSHAPE
Dim powerSHAPE As New PSAutomation(Autodesk.ProductInterface.InstanceReuse.UseExistingInstance)
Dim psModel As PSModel = powerSHAPE.ActiveModel
powerSHAPE.FormUpdateOff()
powerSHAPE.RefreshOff()
powerSHAPE.DialogsOff()
'Dim ImportFile As Autodesk.FileSystem.File = New Autodesk.FileSystem.File("C:\Users\dhernaal\Documents\69957-O1.igs")
'psModel.Import(ImportFile)
Dim startPoint As Autodesk.Geometry.Point = New Autodesk.Geometry.Point(0, 0, 0)
Dim endPoint As Autodesk.Geometry.Point = New Autodesk.Geometry.Point(10, 5, 0)
Dim myLine As PSLine = psModel.Lines.CreateLine(startPoint, endPoint)
Dim lineLength As Autodesk.Geometry.MM = myLine.Length
Dim inchLength As Inch = CType(lineLength, Inch)
MessageBox.Show("This line is" & lineLength.ToString & " mm")
powerSHAPE.FormUpdateOn()
powerSHAPE.RefreshOn()
powerSHAPE.DialogsOn()
End Sub
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles b1.Click
powerSHAPE.RunMacro(macroFile:=New Autodesk.FileSystem.File("C:\Users\dhernaal\Documents\Damian\RUTINA.mac"))
thanks
Message 6 of 12
This should work:
Public Class Form1
Dim powerSHAPE As PSAutomation
'ACTIVAR powerSHAPE
powerSHAPE = New PSAutomation(Autodesk.ProductInterface.InstanceReuse.UseExistingInstance)
End Sub
Luke Edwards
Message 7 of 12
I´m so sorry. But, now I have other error
please, see image  below
Message 8 of 12
Can you post your code, something must be wrong in it?
Luke Edwards
Message 9 of 12
Were you able to resolve this?
Luke Edwards
Message 10 of 12
Good day Luke.
Not, yet  and if I can post my code, I dont know what Iam doing wrong.
How do you make another button perform an action without it opening the powershape again?
Can you show me an example?
 My second button can do it other action, but this open the powershape again. I dont understand
thanks for you help and exuse me my english is not very well. I am Mexican.
Regards
Message 11 of 12
I have extended your original example here... This should work...
Public Class Form1
  Dim model As PSModel
    'ACTIVAR powerSHAPE
    model = powerSHAPE.ActiveModel
  End Sub
  End Sub
End Class
Luke Edwards
Message 12 of 12
This is correct.
Thanks for you help.
I had an error but with you help this work very well.
