I use the copyright value of the assemblyInfo. However there are other ways, I asked ClaudeAI about it, and I got the following answer from ClaudeAI :
C# : when starting a new app (Windows application, .net framework 4.8), where can I store the name of the programmer, and how can I retrieve the name of the programmer to be used in a string ?
I'll help you create a solution for storing and retrieving the programmer's name in a .NET Framework Windows application. Here are a couple of common approaches:
// Method 1: Using App.config
// First, add this to your App.config file:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<appSettings>
<add key="ProgrammerName" value="John Doe" />
</appSettings>
</configuration>
// Then in your code, add this using statement:
using System.Configuration;
// To retrieve the programmer name:
public string GetProgrammerNameFromConfig()
return ConfigurationManager.AppSettings["ProgrammerName"] ?? "Unknown Programmer";
// Method 2: Using Assembly Information
// In AssemblyInfo.cs (found in Properties folder), add or modify:
[assembly: AssemblyCompany("Your Company Name")]
[assembly: AssemblyCopyright("Copyright © 2025 by Your Programmer Name")]
// To retrieve the information:
using System.Reflection;
public class ProgrammerInfo
public string GetProgrammerNameFromAssembly()
// Get copyright info which contains the programmer name
var copyright = Assembly.GetExecutingAssembly()
.GetCustomAttribute<AssemblyCopyrightAttribute>()?.Copyright ?? "Unknown";
// Parse the copyright string to extract the programmer name
// Assuming format: "Copyright © 2025 by Your Programmer Name"
string programmerName = copyright.Split(new[] { "by " },
StringSplitOptions.RemoveEmptyEntries).LastOrDefault()?.Trim() ?? "Unknown Programmer";
return programmerName;
// Method 3: Using a dedicated Settings file
// Right-click your project -> Properties -> Settings
// Add a new setting:
// Name: ProgrammerName
// Type: String
// Scope: Application
// Value: Your Name
// To retrieve the setting:
public string GetProgrammerNameFromSettings()
return Properties.Settings.Default.ProgrammerName;
// Usage example:
public void DisplayProgrammerInfo()
// Using App.config
string configName = GetProgrammerNameFromConfig();
MessageBox.Show($"Programmer (from config): {configName}");
// Using Assembly info
var programmerInfo = new ProgrammerInfo();
string assemblyName = programmerInfo.GetProgrammerNameFromAssembly();
MessageBox.Show($"Programmer (from assembly): {assemblyName}");
// Using Settings
string settingsName = GetProgrammerNameFromSettings();
MessageBox.Show($"Programmer (from settings): {settingsName}");
I've provided three different methods for storing and retrieving the programmer's name, each with its own advantages:
- App.config: Good for application-wide settings that don't change often. Easy to modify without recompiling.
- Assembly Information: Built into the assembly metadata. Good for version control and official product information.
- Settings file: The most user-friendly approach, as it can be managed through Visual Studio's Properties window.
The most recommended approach would be Method 3 (Settings file) because:
- It's easy to maintain through Visual Studio's UI
- It's strongly typed
- It's designed specifically for application settings
- It can be scope-controlled (Application vs. User)
To implement the Settings approach:
- Right-click your project in Solution Explorer
- Select Properties
- Click on the Settings tab
- Add your programmer name setting
- Save the changes
Then you can use it as shown in the code example. Would you like me to elaborate on any of these methods?
Great. Let me try this now.
Good luck with the implementation! Let me know if you encounter any issues or need clarification on any of the methods. Since the Settings approach is the most straightforward, I recommend starting with that one. Don't forget to save your project after adding the new setting in the Properties window.
Claude can make mistakes. Please double-check responses.
