Export Wizard with Visual Basic
hugo_wy
Message 1 of 9
hugo_wy
Hi.
I am using PowerShape 2015 R2 and Visual Basic 2010 Express.
I am doing a program and i am stuck with this situation.
I need do export everything that is VISIBLE.
If i use this macro and run it in PowerShape, it works fine.
FILE EXPORT WIZARD
NEXT
D:\Moldes\tmp_elec.dgk
EXPORTTYPE VISIBLE
WIZEXPORT
EVERYTHING PARTIALBOX
But if i use it with Visual Basic 2010, don´t work.
PSHAPE.Execute("FILE EXPORT WIZARD")
PSHAPE.Execute("NEXT")
PSHAPE.Execute("D:\Moldes\tmp_elec.dgk")      'It stops here. Don´t use the path.
PSHAPE.Execute("EXPORTTYPE VISIBLE")
PSHAPE.Execute("WIZEXPORT")
PSHAPE.Execute("EVERYTHING PARTIALBOX")
Note:
This works in Visual Basic, but don´t export everything that is VISIBLE, like "Workplanes" that aren´t activated.
PSHAPE.Execute("FILE EXPORT D:\Moldes\tmp_elec.dgk")
Replies (8)
Message 2 of 9
l.ponsaerts
To export something I use the API code. Ex.g. to export a model to a AutoCad dwg file :
Public Sub WriteDWGFile()
Dim dwgfile As New Autodesk.FileSystem.File(Reg_OutputFolder & "\" & Frm_Main.g_Fname & ".dwg")
PSModel.Export(dwgfile, ExportItemsOptions.Selected, ExportWorkplanes.World)
End Sub
Message 3 of 9
hugo_wy
Hi.
The problem is not exporting what is selected. That i know how.
The issue is exporting what is visible.
When i use the Visual Basic e gets stuck in the path of the file.
Message 4 of 9
luc_ponsaerts
The example I gave was a hint...
The .Export function is using the property ExportItemsOptions, which can also take the value "Visible".
PSModel.Export(dwgfile, ExportItemsOptions.Visible, ExportWorkplanes.World)
End Sub
I didn't try this yet, but it should work.
Message 5 of 9
luc_ponsaerts
I also looked at the custom core source.
In the source I found (simplified version)
PSHAPE.Execute("FORMUPDATE OFF");
PSHAPE.Execute("FILE EXPORT WIZARD", "TARGET UNKNOWN");
PSHAPE.Execute("NEXT", exportFile.Path);
PSHAPE.Execute("EXPORTTYPE VISIBLE");
PSHAPE.Execute("NEXT");
PSHAPE.Execute("EXPORTTYPE WORLD");
PSHAPE.Execute("WIZEXPORT");
PSHAPE.Execute("FORMUPDATE ON")
Message 6 of 9
hugo_wy
That works perfectly.
Thanks a lot.
Message 7 of 9
corl_jammy74
Community Visitor
Community Visitor
It is hard to believe that  بازی انفجار
Message 8 of 9
corl_jamm_y74
Community Visitor
Community Visitor
PSModel.Export(dwgfile, ExportItemsOptions.Selected, بازی انفجار آنلاین ExportWorkplanes.World)
End Sub
Message 9 of 9
corljam_m_y_
Community Visitor
Community Visitor
hats off to writer اپ انفجار
