Executing macro commands in API
luc_ponsaerts
Message 1 of 1
luc_ponsaerts
I have this macro that writes the data of an info window into a file , I call the macro in Powershape :
INFO SHOW
UPDATE_INFO OPTIONS DETAILEDINFO ON SHOW
INFO_POPUP SAVE Filename FileDialog Write Validate C:/temp/selectedfaces.txt
UPDATE_INFO DISMISS
Works perfectly, the file with the data is created.
Now, I implement these commands in my c# app :
pShape.Execute("INFO SHOW");
pShape.Execute("UPDATE_INFO OPTIONS DETAILEDINFO ON SHOW");
pShape.Execute("INFO_POPUP SAVE Filename FileDialog Write Validate C:/temp/selectedfaces.txt");
pShape.Execute("UPDATE_INFO DISMISS");
No file is created.
When I call the macro in the c# app :
string macroPath = dirName + macroName;
macroPath = macroPath.Replace("\\", "/");
pShape.Execute("MACRO RUN " + macroPath);
Perfect. The file with the data is created.
Some ideas ?
Replies (0)
