access to Windows Registry keys
l.ponsaerts
l.ponsaerts
Hi all,
I am in the midst of refactoring an old vb6 app to VB.net in VS2022.  (Win11)
With VB6 and PM2012 I had access to all registry keys under /localmachine/Delcam/, and also to /localmachine/Delcam/Powermill
using :
Dim PowerMILL As RegistryKey = Registry.LocalMachine.OpenSubKey("SOFTWARE\Autodesk")
Dim List_PM As String() = PowerMILL.GetSubKeyNames
Now, with vb.net most of the keys are invisible to PowerMILL As RegistryKey  and
Dim PowerMILL As RegistryKey = Registry.LocalMachine.OpenSubKey("SOFTWARE\Autodesk\Powermill")
creates an exception at the second line because SOFTWARE\Autodesk\Powermill is not accessible.
What do I do wrong here ?
l.ponsaerts
herby the test code
l.ponsaerts
found  a solution. The openkey(path) only shows 32 bit software keys.
In order to get to the 64 bit ones :
PowerMILL = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, RegistryView.Registry64).OpenSubKey("SOFTWARE\Autodesk\Powermill")
List_PM = PowerMILL.GetSubKeyNames
luke.edwards.autodesk
The alternative is to target your solution to x64. I would suggest you want to do this as standard these days anyway, especially if you want to interact with the products.
Luke Edwards
Consulting Services Manager
l.ponsaerts
Luke, didn't know that. Thanks.
