Hallo
Also im Moment benutzen wir nur den Allgemein Wert.
PowerMill > print par $tool
(REF) id:3a4bd96565cdd3960000b3b600000000 = (ROOT: tool:12 R0,5 (GQHG1203R05) (12U9T012023X4R00) (20 06 606/12 ZYL) L43)
Tags: (ARRAY)
FeedPerRevolution: (MAP)
finishing: (MAP)
profiling: (REAL) 0,0 [L]
plunge_milling: (REAL) 0,0 [L]
slotting: (REAL) 0,0 [L]
face_milling: (REAL) 0,0 [L]
drill: (REAL) 0,0 [L]
copy_milling: (REAL) 0,0 [L]
general: (REAL) 0,0 [L]
roughing: (MAP)
Error: (STRING)
Coolant: (ENUM) standard
TipRadius: (REAL) 0,500000 = 0,5 [L]
Length: (REAL) 10,0 [L]
RadialDepthOfCut: (MAP)
finishing: (MAP)
drill: (REAL) 0,0
general: (REAL) 0,5833333333
roughing: (MAP)
drill: (REAL) 0,0
general: (REAL) 0,0
IsHolderFromModel: (FUNCTION)
ToolFamily: (STRING)
UserParameters: (MAP)
HolderSetValues: (ARRAY)
[0] (MAP)
UpperDiameter: (REAL) 31,4 [L]
Length: (REAL) 58,9 [L]
Ignore: (BOOL) 0
LowerDiameter: (REAL) 24,0 [L]
[1] (MAP)
UpperDiameter: (REAL) 35,4 [L]
Length: (REAL) 2,0 [L]
Ignore: (BOOL) 0
LowerDiameter: (REAL) 31,4 [L]
[2] (MAP)
UpperDiameter: (REAL) 63,0 [L]
Length: (REAL) 16,000000000000007 [L]
Ignore: (BOOL) 0
LowerDiameter: (REAL) 63,0 [L]
[3] (MAP)
UpperDiameter: (REAL) 180,0 [L]
Length: (REAL) 80,0 [L]
Ignore: (BOOL) 0
LowerDiameter: (REAL) 180,0 [L]
HolderProfile: (MAP)
ShankClearance: (REAL) Tool.HolderProfile.Clearance = 2,5 [L]
Clearance: (REAL) min(2,5;0,25*Rootpar.Diameter) = 2,5 [L]
Tolerance: (REAL) min(Tool.HolderProfile.Clearance;Tool.HolderProfile.ShankClearance)*0,1 = 0,25 [L]
MaximumDiameter: (REAL) 0,0 [L]
HolderName: (STRING) SK40 D12 A80 302235_12 (GARANT)
ShankSetValues: (ARRAY)
[0] (MAP)
UpperDiameter: (REAL) 11,5 [L]
Length: (REAL) 13,0 [L]
LowerDiameter: (REAL) 11,5 [L]
[1] (MAP)
Length: (REAL) 20,0 [L]
[2] (MAP)
UpperDiameter: (REAL) 12,0 [L]
Length: (REAL) 45,0 [L]
LowerDiameter: (REAL) 12,0 [L]
AxialDepthOfCut: (MAP)
finishing: (MAP)
drill: (REAL) 0,0
general: (REAL) 0,0166666667
roughing: (MAP)
drill: (REAL) 0,0
general: (REAL) 0,0
Type: (ENUM) tip_radiused
Identifier: (STRING) 12 R0,5 (GQHG1203R05) (12U9T012023X4R00) (20 06 606/12 ZYL) L43
CuttingSpeed: (MAP)
finishing: (MAP)
profiling: (REAL) 0,0 [L/T]
plunge_milling: (REAL) 0,0 [L/T]
slotting: (REAL) 0,0 [L/T]
face_milling: (REAL) 0,0 [L/T]
drill: (REAL) 0,0 [L/T]
copy_milling: (REAL) 0,0 [L/T]
general: (REAL) 185,0 [L/T]
roughing: (MAP)
general: (REAL) 0,0 [L/T]
NumberOfFlutes: (INT) 2
IDTracksName: (BOOL) 1
Overhang: (REAL) 43,0 [L]
FeedPerTooth: (MAP)
finishing: (MAP)
drill: (REAL) 0,0
roughing: (MAP)
drill: (REAL) 0,0
general: (REAL) 0,0
HolderConnectionType: (STRING)
Description: (STRING)
IsTurningType: (FUNCTION)
Number: (MAP)
Value: (INT) 1
UserDefined: (BOOL) 1
StockMaterial: (STRING) 1
TurningDepthOfCut: (MAP)
finishing: (MAP)
roughing: (MAP)
Status: (STRING) Gültig
