XY-stock given in toolpath not shown in output NC file
karan30782
karan30782
Hi ! all,
I have to show radial & axial thickness value in which I have given in toolpath.
Thanks to anyone help..
Regards.....
Accepted solutions (3)
Replies (14)
Arun.rs
Hi @karan30782
Thanks for raising your concern via Forum.
I have tested the post at my end and I am getting expected result. Did you given the values in both the fields?
Regards
Arun.RS
Technical Consultant - Post Processor
karan30782
Thanks & regards @Arun.rs
rui_rita
Hi @karan30782  and @Arun.rs
last time I check the value only shows correct if the toolpath have both thickness.
if you have just set one value,  could be incorrect, it shows the last value used.
example: 1st toolpath have thickness set to 0.1 and axial thickness 0.05 and the second toolpath have only set the thickness 0.01, the axial thickness isn't used
the post will wirte :
1st toolpath ( stock: XY 0.1 Z0.05)
2nd toolpath ( stock: XY 0.01 Z 0.05)
only in tables the output is correct, if you don't have the axial thickness set will output empty
Os melhores cumprimentos | Best regards
Rui Rita
________________________________
NEWCAM, Lda.
karan30782
Hi ! @Arun.rs @rui_rita
Thanks for your reply,
But in my case when I use the option file to post the nc program from my pc xy-0.0 & z-0.0
And
When I use another pc to post the nc program value is correct (as expected).
I don't know why this happens all the time...
Please give your suggetion.
Thanks in advance to both of you !
rui_rita
Hi @karan30782 ,
is both pc's using the same version of AMPPU ?
Rui Rita
NEWCAM, Lda.
karan30782
Hi ! @rui_rita
Thanks for reply.
I have checked both pc's are using same APPMU, which is APPMU2021
Any suggestions?
Thanks !
rui_rita
can you send the cut file from each pc
Rui Rita
NEWCAM, Lda.
karan30782
Hey @rui_rita
I have attached the file. Please have a look.
Thanks in advance !
rui_rita
Hi, the problem seems to be when you write it from PowerMILL,
have they both the same version and update? if you don't have the lastested update, I suggest you do it.
Rui Rita
NEWCAM, Lda.
karan30782
Hi !   @rui_rita  and  @Arun.rs
I'm still stuck with the problem..
When I use the post processor to post NC program from another PC, all X,Y,Z stock shows.
But when I post from my PC XYZ_Thickness shows 0.0
Can someone please suggest me anything ?
Note:- Configuration and software version of both PC's are same
Thanks ALL !
Awaiting response ..............
karan30782
@rui_rita
Hi !
both PC are using the same version and update for POWERMILL & AMPPU
I have even Uninstalled Powermill and all from my PC and did a clean installation, but problem not yet solved.
Regards !
j.lacrasse
Hi @karan30782
Did you check you regional settings? I found out that it hinder macro to work properly. On one computer my macros worked fine but on the second one it wasnt. It was only the regional settings. You may want to set your not working station as the other.
J.Lacrasse
karan30782
Hey !  @j.lacrasse
Thanks for replying, but I have checked the regional setting it's as required.
So no luck yet.
Even I have performed a clean installation also.
karan30782
Hi ! ALL,
Thanks for your valueble support, but problem was not solved after multiple efforts.
So, I uninstalled all Autodesk product and performed a clean installation.
And now everything works fine.
Thank All, Once Again.......
