Weihong 3axis lathe DSP post processor powermill
Facing problem with post processor.. bought a Chinese weihong nk105 g2 DSP controlled lathe. Autodesk engineer says to get me example for NC code and I don't have .
matthew.nichols
Just wanting to make sure...your subject line has powermill mentioned.  Are you using Inventor HSM or HSMWOrks?
Is there anyway to contact the manufacturer to get a programming manual or sample code that could run on the machine showing capabilities?
Matthew Nichols
Adoption Specialist - MFG
I bought newly power mill 2017 the indian region of Karnataka. The
Autodesk engineer who comes trains us is required example of NC file to
make the post processor. I am just a customer
NanchenO
If you receivedd any manual with your machine, there should be enough information in it to make a postprocessor.
If not, try the control's manufacturer Internet site.
Olivier
Hi @Anonymous I have noticed you mentioned that you have bought a Lathe.
FeatureCAM is more suitable for lathes than Powermill. Have you seen FeatureCAM?
George
I already buy powermill
