Viewmill state mac
Viewmill state mac
rafael.sansao
Advisor Advisor
Viewmill state mac
rafael.sansao
Hello friends,
Is there a macro command to check if the Viewmill is on / off?
Rafael Sansão
OptiNC - www.optinc.tech
Good Afternoon,
I am not sure if this is exactly what you're asking but below I wrote what it will said if viewmill is on or if it's turned off.
ON: SIMULATE VIEWMILL START
OFF: SIMULATE VIEWMILL SUSPEND
Also you can quickly tell if the viewmill button is Red or Green.
rafael.sansao
Thanks for the answer.
I know how to turn the Viewmill on or off.
What I need to do is check if it's on or off. Something like:
IF Viewmill.state == 'ON' {
   code is ON...
Rafael Sansão
5axes
2017 you can use :
widget('ViewmillBar.VMOnOff').Value    :  TRUE = 0N   FALSE = OFF
2018 :
widget('Ribbon.Simulation.ViewMill.VMOnOff').Value   same values
rafael.sansao
Tks @5axes
To figure out the value, do you add the button in the toolbar and export the toolbar as xml? open the xml and see the parameter name?
Or is there some easier way?
Rafael Sansão
5axes
Just launch the MACRO Command
MENUBARHELP DYNAMIC WIDGETNAMES
Then you will have for every button or field the name of the component instead of the Help message
You can also use :
MENUBARHELP DYNAMIC FORM
To modify the settings via the Dynamic help form
