Announcements
Trying to make a pattern for a ball mill path
Hi all,
I'm trying to program a relief cut on the backside of a trimming die. It has a 3/16 rad. and we use a 3/8 ball for the finish cut. Used to be we would offset the top edge of the fillet in by the radius amount and down the same. I'm having an overcut situation as the cut goes up and down on the Z. Hoping someone knows a better way.
iamcdn79
If its one pass your looking for have you tried 'Corner pencil' toolpath?
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
j.lacrasse
Hi @Anonymous
I'd use pattern finishing. I'd offset the top edge as you did, and use the drop option. Maybe you'd need to ignore the top surface if they are straight in Z. Then collision/gouge check everything and that'd do what you want I think.
Best regards,
J.Lacrasse
J.Lacrasse
Thanks guys, I used your suggestion j.lacrasse and it worked. I had to lie to it about the tool diameter (.372) but it cut the shape. I was doing 1 step too many.
Thanks again,
John
