Surface projection finishing issue from distance projection surface reference
jeanmarc.teste
jeanmarc.teste
Dear all
Can you help me . i have issue with sCapture.JPGurface projection finishing toolpath.as you can see on the picture.
I look for hidden commands to define the distances end  limits of surface projection.
Thank you in advance
dames99
EDIT SURFPROJ AUTORANGE ON
Real $rangemax=0
Real $rangemin=0
$rangemax=INPUT "Enter maximum +maximum range"
$rangemax=INPUT "Enter maximum -minimum range"
EDIT SURFPROJ AUTORANGE OFF
EDIT SURFPROJ RANGEMAX $rangemax
EDIT SURFPROJ RANGEMIN $rangemin
Jonathan_Artiss19
@jeanmarc.teste
You can copy paste this command into the echo commands window and it will populate a hidden page in the projection surface toolpath.
preview strategy_projection_range_form
Open the page in the toolpath window and enter a min max value.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
M_Hennig
I believe the above fix only works for surface finishing toolpaths, you must use the type in commands for the others. Wouldn't it be nice to just have this part of the original form, instead of typing in little top secret commands that most users know nothing about..??
jeanmarc.teste
i agree with you.
Thank.
anybody can help me plz i have a problem in surface projection strategy in power mill
i cant make good surfase for projection I want the tool motion along the X-axis Reach the minimum.
may i use macro command for getting perpendecular toolpath like this video
i'm sorry for my poor english.
hi mr
can you help me i have a problem about surface projection  strategy in power mill
i cant make  perpendecular toolpath I want the tool motion along the X-axis Reach the minimum.
or my surface have a problem
i attached my project if you have a time see it
thanks.
