03:01 AM
- Mute
- Permalink
- Report
When I create a stock model for op 1 and select - drawing options - show all it shows the stock model all around the job eg under the under cut and the pocket on the rear end. But when I then select -drawing options- show rest, it only shows the rest material for op1 and shows nothing under the under cut or rear pocket, but when I come to machine op2 on the job (the other side) and select rest material it wont show the rest material. Ive attached to images to show more clear my issue. its seems like the stock model drapes over the job on op1 so do you need to create a separate stock model for op2 2. Thanks.
