start from old project
psx2
Message 1 of 21
psx2
hi,
which is  the correct way to start from an old project ...
ex:
i've 10 toolpath one ncprogram  1 workplane called ZP and one featurset named hole.
i delete all models,  i select all feature and delete them and save template.
then i load the new models and load the template but the new model have one workplane with same name "ZP" ( but with different position) and in powermil i've two workplanes called zp and zp_1 !!!!
how should i do ?
thanks
Replies (20)
Message 2 of 21
Remove unused workplane?
Mateusz
Message 3 of 21
psx2
thanks but i can't delete the workplane because is used from many toolpaths
Message 4 of 21
1. Activate Workplane  'ZP'
2. Select all toolpath
3. Right click on toolpaths-> Edit ->Set Named Parameter-> 'Workplane' (without dot '.') ->OK
Message 5 of 21
psx2
ok,
thanks.
Message 6 of 21
rui_rita
you could add this to your user toolpath menu "Toolpath.xml"
<button
command="EDIT PAR selected 'workplane'"
label="Define Active Workplane"
multiple_selection="allowed"
another idea that you may need is some new boundaries
you can use this in the user toolpath menu
<button
command="EDIT PAR selected 'boundary'"
label="Define Active Boundary"
Os melhores cumprimentos | Best regards
Rui Rita
________________________________
NEWCAM, Lda.
Message 7 of 21
psx2
sorry but i've created an home directori "h:\Pmill" and then i've created a system variable  called "Home" and valorized with "H:\".
In Pmill folder i've created the file "Toolpath.xml" and i've copied and pasted your code
<button
but not work !
thanks
Message 8 of 21
rui_rita
<?xml version="1.0" ?>
<menupage>
<button
label="Define Fronteira Activa"
<spacer multiple_selection="allowed"/>
<button
label="Define Plano Trabalho Activo"
</menupage>
Rui Rita
NEWCAM, Lda.
Message 9 of 21
psx2
sorry but not work
in h:\pmill i've tree file:
- - - - - - - - - - -- - - - - - Toolpath.xml
<menupage>
<button
<button
</menupage>
- - - - - - - - - - -- - - - - - user_menu.xml
<menus xmlns="x-schema:user_menu.xsd">
<usermenu value="user_menu">
<menupage label="This is the Title">
<spacer/>
<button
label="Button Label"
command="SOME POWERMILL COMMAND"/>
</menupage>
</usermenu>
</menu>
- - - - -- - - - - - - user_menu.xsd
copied from c:\program\powermill\sys\hci\popups\TreeSchema.xlm
thanks
Message 10 of 21
rui_rita
try this file...
Rui Rita
NEWCAM, Lda.
Message 11 of 21
psx2
thanks but not wok !!
Message 12 of 21
rui_rita
what happens???
you get a error...
the menu doesn't appear?
give me something so I can help you...
what version do you have?
Rui Rita
NEWCAM, Lda.
Message 13 of 21
psx2
simply the menu not appear !
i've pm standard 2017 sp4
Message 14 of 21
5axes
Cool !, thanks for the sample file @rui_rita. I was wondering why you are using "<spacer multiple_selection="allowed"/>" in the spacer tag . But it's very useful in case  of multi selection to keep the separation line in the user menu. I will update my xml files according to this syntax.
Cuq
Message 15 of 21
rui_rita
@psx2
are you selecting the toolpaths?
I don't see any reason why it wouldn't work.
can you upload a video ?
@5axes
this way you get a much cleaner usermenu... and one of the thing I ask a long time ago was te ability to create "titles" in the usermenu, but it's not possible for now, as far as I know
Rui Rita
NEWCAM, Lda.
Message 16 of 21
5axes
To be sure save your XML file in your Macro directory.  Like that  you are sure that the directory is reconized and used by PMILL. And you don't need to indicate the macro call with pth complet path. you just need to use : <button command='MACRO "Unsafe_Plunge" "%s"' label="Controle plongee non sure" multiple_selection="allowed"/>
Message 17 of 21
psx2
thanks !!!!
powermill not recognize the folder !!!!!!
now work but only toolpath menu ,
user menu not work . The file it's located in the same folder of toolpath.xml and contain
<spacer/>
<button
</menupage>
</usermenu>
</menu>
thanks thanks thanks !!!!
PS:
i can't use screencast !!!   record but don't upload !!!
Message 18 of 21
rui_rita
the last tag you have
</menu>
and must have
</menus>
mark as solved if it's the case
Rui Rita
NEWCAM, Lda.
Message 19 of 21
psx2
thanks !!!!
now work all !!!!
very happy
thanks
Message 20 of 21
rui_rita
mark the awser for the first doubt as well, so when others have the same doubt as you can see the 2 answers
Rui Rita
NEWCAM, Lda.
