spiral fit arc
spiral fit arc
Message 1 of 10
spiral fit arc
ist possible in constant z finish to have spiral and fit arc togather in order to have ij format and decrease the number of line
Replies (9)
Message 2 of 10
iamcdn79
When you select the spiral option for constant-z the arc fit setting gets turned off so it is not possible unless you make your own rads in your cad.
People like myself have been requesting this feature for years but doesn't get implemented but someone requests the ribbon feature interface and that gets changed right away, go figure Smiley Frustrated
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 10
I know that but always spcicaly when making holse by canstantz I use feature and helical stratigy its get better result
Sent from my Huawei Mobile
Message 4 of 10
johnc4668
@iamcdn79 @Anonymous Have you heard any news on powermill using arc fit corners on spirals or on steep and shallow yet? Whats your workaround for this right now? thanks
Message 5 of 10
iamcdn79
Last I heard was they are in the process of implementing it by adding an stl model with the necessary larger rads in the background calculation. When that comes out I have no idea.
My workaround is either having to create my own fillets in my cad software. It is painful and tedious at times depending on the complexity of the model or just clear the corners with a smaller tool then go back to the larger tool to finish.
Windows 11 Pro
Message 6 of 10
johnc4668
@iamcdn79 Ok cool, i was thinking about splitting the steep and shallow into a constant z and a raster but thats more tool paths and i dont like it arcing on and off all the time and putting lines in walls. Powermill seems to be behind on this feature, we can do this all day long with visi and worknc.
Message 7 of 10
M_Hennig
There is a way to arc all corners using a stock model and the "stock engagement" option, BUT you need a really good tight tolerance stockmodel to get it to work decently. Even so, it's still a workaround in my book.
Message 8 of 10
johnc4668
@M_Hennig thanks for this info. Can you send me a screen shot of your stock engagement/ stock model parameters to get the toolpath to arc in the corners?
Message 9 of 10
M_Hennig
https://www.youtube.com/watch?v=jryFKj0hW54
Just to be clear, you need a very tight tolerance stock model to get decent results.
Message 10 of 10
5axes
https://forums.autodesk.com/t5/powermill-forum/toolpath-s-links-isssue/m-p/7345546#M5714
EDIT TOOLPATH  ; HORIZONTAL_COIN_FI  1 0.01  1 = Radius value and 0.01= Tolerance
But it works only for non spiral toolpath, Spiral toolpath are automaticaly converted into Z Constant toolpath style.
Sometimes in some special case it's possible to use a pattern but depending of the quality of the original toolpath, it's not always possible to insert an Arc everywhere.corner.jpg
