Simple .mtd file
Simple .mtd file
Simple .mtd file
I am looking at using a very simple .mtd file to verify an NC program.  All I want to do is use a single surface to represent the machine table and verify the NC program in order to check the tool does not gouge when profiling the job.  I wan to do it in an NC program wit han .mtd instead of gouge checking against a surface in order that I get the green tick instead of yellow question mark for the NC program.
I am completely new to .mtd files and have been editing the examples.  When adding the .mtd file it want to reference machine head etc but all I want is a single surface (I have already created a .dmt for this) with no axis or anything.  Is this possible and if so how do I go about it?
iamcdn79
In the top right corner there is a pdf document explaining how to make a mtd file
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Meysam_Ghorbani
you can download all of machine data in blow link
https://t.me/powerMILLTraining/5048
Hi @Anonymous ,
First of all Go through given document (MTD User Guide). Try to build machine by your self if you are facing any problem while creating/ writing script , Exchange the model file , or calculating any parameters you can forward the error in forum.
There are number of experts in Autodesk forum. We would like to help you and guide. But first try by your self of not then my dear we are here for you.
Krupal V
hrh46
Dear Andre
I made a special machine and need MTD file for it.
kindly help me.
let me have your private email address. mine is hr_hadizadeh@yahoo.com
I have a spindle on Z . z axis moves with X. and  c axis)rotary table is fixed at 0,0,0
best regards
hamid
