Short ramp segments, what im i doing wrong?
johnc4668
johnc4668
Fellas,
See pic. Sometimes in the pattern finishing toolpath, it wants to ramp in on a small segment. How do i get around this?
thanks!
Replies (15)
craig.shipley
Autodesk Support
Autodesk Support
Hi
Not sure if it's just my browser but I'm unable to see the image, could you please attach?
Jonathan.Artiss-DSI
Whats your ramp settings?
Are you following the toolpath?
Maybe upload the project for us to adjust it.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
johnc4668
see attachment
johnc4668
it has to do with the segments of the pattern i think, it struggles on the number 5 alot. I see the segments when im in the editor
craig.shipley
Autodesk Support
Autodesk Support
I'd assume it's to do with how the curve has been created or what it looks like.  Can you share the project (or even just a stripped out example with the 5 curve inside?)
johnc4668
here you go
Jonathan.Artiss-DSI
There is an overlap in the pattern. If you correct this, the ramping will work.
Jonathan Artiss
craig.shipley
Autodesk Support
Autodesk Support
Looks like there are duplicates here, think this may be the issue
Kind Regards
johnc4668
@Jonathan.Artiss-DSI  thanks, can you explain how to correct this? I dont want to have to modify this everytime. Is this a setting im missing somewhere?
craig.shipley
Autodesk Support
Autodesk Support
Actually, take a closer look at the curves...
Jonathan.Artiss-DSI
The wireframe is causing overlaps and broken segments.
I'm guessing you grab the wireframe and use insert model?
Jonathan Artiss
johnc4668
@Jonathan.Artiss-DSI  im using pattern> curve editor> collect
craig.shipley
Autodesk Support
Autodesk Support
Hi
Yea so taking a look at it, the model wireframe has some issues which would need addressing before creating your pattern from the wireframe.
Alternatively you could just create a fresh pattern and your own text (using Delcam Gothic font).
Would this be OK?
If not, you probably need to see how the text is being created at CAD stage (you'd be better off having composite curves rather than wireframe).
Hope this helps
Kind Regards
craig.shipley
Autodesk Support
Autodesk Support
Created text in curve editor, looks fine after that.
Kind Regards
Jonathan.Artiss-DSI
I agree with Craig, either have the wireframe text fixed or just create your own using the horizontal pattern text and the Delcam Gothic text.
Jonathan Artiss
