Harvey Tool Library
Harvey Tool Library
jim
Message 1 of 9
Harvey Tool Library
jim
Looking for guidance from anyone who may have had success loading the Harvey Tool library into 2020 Powermill. I noticed in the 09/2019 Harvey catalog that HSM and Fusion 360 are supported, unfortunately Powermill seems to be an afterthought…perhaps in 2020🤔
Replies (8)
Message 2 of 9
smackayPFSC4
I'm betting that HSMworks and Fusion 360 have a more modern tool database than the ancient Access database that PowerMill provides us. We've been after Delcam, and now Autodesk to switch over to a real multi-user SQL database(MySql, SQLserver, MariaDB, etc...).
But, in any case, a tool library shouldn't be all that difficult to supply to PowerMill. Just have to export the tool as a template object.
Message 3 of 9
5axes
Working on a solution, but still have a lot of bug ! it's working for some holder library but tool library are much more complex
Message 4 of 9
5axes
close to a result but need to validate the cutting conditions.
Message 5 of 9
5axes
Finaly it's not so easy. First of all the library by itself are quite huge. More than 18000 ref only for the End Mill reference. So integrate all these refrences into a Pmill project to create a template are not so obvious. Next point the name of the tool are very long Ie : HARVEY - MINIATURE END MILL - STUB & STANDARD - 4 FLUTE - 0.0620 DIA X 0.093 LOC X AMORPHOUS DIAMOND COATED
And the tool library of Pmill is actualy limited to 50 characters.
So it's not possible to integrate such reference into the Access library. So the only way is to create the reference you need one by one :
Visu_outil_217X.exe
or
Visu_outil_217X.zip
Actual Releasae 2.17.34 with revised FUSION 360 tool library import (jason format) and Direct export in PowerMill.
Message 6 of 9
5axes
From Fusion360 to PowerMill
Message 7 of 9
5axes
Modification of this interface release 2.17.36
  • the product-id is now used to define the Tool Name.
  • Description is not any more used as Tool Name but stored in the Description field of the Powermill Tool.
  • An User Defined Setting  is used to keep the information of the product-link between the softwares.
Message 8 of 9
5axes
Still have some issues with FreeFrom tools to convert these tools in Powermill.   Define this tool as ROUTING TOOL or FORM TOOL.  Have to wait  for the next release 2.17.37.
Harvey Tool/Specialty Profiles
Message 9 of 9
5axes
With the release 2.17.38 almost every reference are now correctly read and exported into PowerMill
Visu_outil_217X.exe
