Running all macros in a folder
In an effort to clean up some of my macro paths/etc I would like to incorporate a "run all in folder" sort of command.
I have no idea how to practically impliment this.
The macros in question are labeled by number eg;
1-Run this
2-Run that
3-Run this too
77-This as well
Right now I have a file named "1000-Run all" that I tend to incorporate and manually assign file locations to it within the macro file but this is INCREDIBLY tedious and inflexible.
The end goal is basically;
-List all the files in this directory in alphabetical order
-For each $file ; macro $file
Im wording this really poorly but help is appreciated. I am getting REALLY tired of updating a bunch of directories by hand.
rafael.sansao
STRING $dir = "C:\dcam\config\macros"
STRING LIST $files = sort(list_files("files",$dir,".mac"))
FOREACH mac IN files {
	MACRO $mac
Rafael Sansão
OptiNC - www.optinc.tech
I've encountered a very similar problem.
Am I able to open powermill projects this way?
STRING $dir = THEDIRECTORY\"
STRING LIST $files = sort(list_files("files",$dir,".pmlprj"))
FOREACH pmlprj IN files {
	FORM RIBBON BACKSTAGE CLOSE PROJECT RECOVERY OPEN PROJSELECTOR
	$pmlprj
I've been hacking away at it but frankly it's a bit above my head.
kukelyk
try this:
FOREACH pmlprj IN files { //FORM RIBBON BACKSTAGE CLOSE
PROJECT RECOVERY OPEN $pmlprj
That seems to do the trick though I may have tripped myself up with my own file structure.
In my case it is P:\Power Mill\Update\
There are many sub-folders within this folder eg;
P:\Power Mill\Update\Plate1\Plate1set1\plate1set1.pmlprj
Is there a way I can set it to look through all the folders within that folder?
kukelyk
list list_files( string flags, string dirpath[, string filetype])
Returns a list of files in the dirpath that optionally matches the filetype. flags can be either "all" (return files and directories), "files" (return just files), or "dirs" (return just directories). If flags ends with "+" then files in subdirectories are also returned.
Outstanding.
I don't know if you are familiar with the existential dread associated with making a few minor tweaks on a thousand plates but you have saved me from it.
