Project folder
Project folder
Felipe_Callegario
Message 1 of 9
Project folder
Felipe_Callegario
Could anyone help me find a solution to my problem. in the macro below it takes me only to the main directory, but I would like to go further and select the folders that are inside them, I will use this macro to save the project.
STRING dirPadrao = "C:\Users\09689322\Desktop\Projetos PowerMill\" //alterar o diretório padrão de projetos
STRING $mName = folder("model")[0].Name
STRING LIST $List_dir = list_files('dirs', $dirPadrao)
INT $Felipe = INPUT CHOICE $List_dir "Selecione o diretório."
Replies (8)
Message 2 of 9
Y.Mahran
Hi @Felipe_Callegario,
If you want to access these sub folders then simply use
list_files('dirs+', $dirPadrao)
instead of
And here is an example to show the difference between them, for the following directory:
This code:
STRING SearchPath = "C:\Users\hp\Desktop\TestFolder"
STRING LIST FoldersList = list_files("dirs", SearchPath)
FOREACH file in FoldersList {
PRINT $file
Will return only return this:
C:/Users/hp/Desktop/TestFolder/TestFolder1
C:/Users/hp/Desktop/TestFolder/TestFolder2
C:/Users/hp/Desktop/TestFolder/TestFolder3
While this one:
STRING LIST FoldersList = list_files("dirs+", SearchPath)
PRINT $file
will include the sub folders:
C:/Users/hp/Desktop/TestFolder/TestFolder1/a
C:/Users/hp/Desktop/TestFolder/TestFolder1/b
C:/Users/hp/Desktop/TestFolder/TestFolder2/1
C:/Users/hp/Desktop/TestFolder/TestFolder2/2
C:/Users/hp/Desktop/TestFolder/TestFolder3/c
C:/Users/hp/Desktop/TestFolder/TestFolder3/d
Hope that my reply is helpful to you.
Message 3 of 9
Felipe_Callegario
First of all I would like to thank you for your answer, but what I need is to be able to choose the folders for me to get to the folder where I want to save the projects.
Message 4 of 9
Y.Mahran
Hi @Felipe_Callegario ,
It seems like you want to "Save As" the project according to the model name & current date (modelName_dd-mm-yyyy), into a certain folder. The following macro lists the folders in the project directory and asks you to choose the folder to "Save As" the project into.
(view in My Videos)
Hope that this macro is helpful to you.
// Initializing some variables
RESET LOCALVARS
STRING mainDirectory = dirname(project_pathname(0), "/")
STRING LIST foldersPathList = list_files("dirs", mainDirectory)
// looping over folders
BOOl matchFound = 0
WHILE (True) {
	// Asking the user to choose a folder to "Save As" the project into
	INT C = INPUT CHOICE $foldersPathList "Choose a folder: "
	STRING choosenFolderPath = foldersPathList[C]
	STRING choosenFolderName = basename(choosenFolderPath, "/")
	STRING queryMsg = "The choosen folder: " + choosenFolderName + crlf + "Yes = Confirm" + crlf + "No = Choose a Sub-Folder"
	$matchFound = Query $queryMsg
	// Asking the user whether to confirm the choosen folder or explore sub-folders
	// If the user confirms the choice, then, the macro "Save As" the project using the model name & current date
	IF ($matchFound) {
		OBJECT time = local_time(time())
		STRING currentDate = time.day + "-" + time.month + "-" + time.year
		ENTITY LIST myModel = folder("Model")[0]
		STRING projectSaveName = myModel.Name + "_" + currentDate
		CD $choosenFolderPath
		PROJECT SAVE AS $projectSaveName
		BREAK
	} ELSE {
		$foldersPathList = list_files("dirs", choosenFolderPath)
		IF is_empty(foldersPathList) {
		  MESSAGE ERROR "There is no sub-folder in (" + choosenFolderName + ")"
		  MACRO ABORT
Message 5 of 9
Felipe_Callegario
Excellent, thank you very much for your help.
Message 6 of 9
phocvet
Is there a way to list the files that have been run to export the nc program?
Message 7 of 9
nubrandao
Nice macro, how do i change the default directory?
the macro show everthing in c:\
i want to d:\projects
Message 8 of 9
nubrandao
how do i change directory to d:\Project
Message 9 of 9
Felipe_Callegario
Just today I saw your request, you must enter your directory replacing where I will leave it demarcated. "mainDirectory"
RESET LOCALVARS
BOOl matchFound = 0
WHILE (True) {
IF ($matchFound) {
BREAK
} ELSE {
  MACRO ABORT
