Program List
Program List
Message 1 of 14
Program List
Hello how can I make a macro with the program list, where I select the programs in which I want to rewrite.
I was trying to do this, but this error is returning.
ENTITY LIST $Selected_ncprogram = INPUT ENTITY MULTIPLE ncprogram "Select program"
FOREACH $tp in ProgramNames {
ACTIVATE NCPROGRAM $tp.Name
KEEP NCPROGRAM
Accepted solutions (3)
Replies (13)
Message 2 of 14
rui_rita
Hi @Anonymous
EXPLORER SELECT NCPROGRAM root
FOREACH $tp in $Selected_ncprogram {
EXPLORER SELECT NCProgram $tp.name TOGGLE
KEEP NCPROGRAM SELECTED
Os melhores cumprimentos | Best regards
Rui Rita
________________________________
NEWCAM, Lda.
Message 3 of 14
thank you very much
Message 4 of 14
rui_rita
No problem.
Mark as solved, so others users can see
Thank you
Rui Rita
NEWCAM, Lda.
Message 5 of 14
I'm trying to do the following operations in the same macro, but this one giving error. what am I doing wrong?
EDIT NCPROGRAM SELECTED TAPEOPTIONS FILEOPEN "C:\Users\Rodolfo\Desktop\Haas.pmoptz"
EDIT NCPROGRAM SELECTED TAPEOPTIONS FILEOPEN "C:\Users\Rodolfo\Desktop\Romi.pmoptz"
EXPORT SETUPSHEETS NCPROGRAM ALL
Message 6 of 14
rui_rita
Hi @Anonymous
Can you tell me in wich line it gives you the error?
Rui Rita
NEWCAM, Lda.
Message 7 of 14
The error occurs in this line:
Message 8 of 14
rui_rita
Hi @Anonymous
I can see any problem can you put a picture with the error
Rui Rita
NEWCAM, Lda.
Message 9 of 14
Follow the image of the error, it is in Portuguese
Message 10 of 14
rui_rita
Ola @Anonymous
I run you code and didn't get any error.
please see you macro code, or attach your macro here
Rui Rita
NEWCAM, Lda.
Message 11 of 14
Hello
follows the macro
Message 12 of 14
rafael.sansao
This error occurs because your macro is not selecting any NC program in the Powermill explorer.
Try this:
FOREACH $nc in $Selected_ncprogram {
	STRING $full_path = pathname('ncprogram',$nc.name)
	EXPLORER SELECT NCProgram $full_path TOGGLE
KEEP NCPROGRAM SELECTED YES
Rafael Sansão
OptiNC - www.optinc.tech
Message 13 of 14
rui_rita
Hi
The error that @Anonymous gets is not because there is no selection, but because of the query that appears tor overwrite the nc files.
never the less the solution from @rafael.sansao solves that issue, and solves the problem if you select ncprograms in a folder.
thank you @rafael.sansao 😉
Rui Rita
NEWCAM, Lda.
Message 14 of 14
Now it works
thank you
