Problem with Macro to load triangle block definition
Jason_McDaniel
Jason_McDaniel
Hello. I'm not sure of the correct syntax I need to get this to work. I'm trying to write a macro to load an exported ViemMill model as block.
FORM BLOCK
EDIT BLOCKTYPE TRIANGLES
// Open Import Browser
STRING $VarModel = ''
$VarModel = FILESELECT "Please select a exported ViewMill state file"
// Load exported ViewMill state model as new Block
GET BLOCK FILEOPEN $VarModel
EDIT BLOCK COORDINATE WORLD
DRAW BLOCK
BLOCK ACCEPT
I'm getting the following error: "Unable to open block definition file '$VarModel' from line 10.
What am I doing wrong?
Thank you,
Jason
iamcdn79
Try
FORM BLOCK
GET BLOCK $VarModel
DRAW BLOCK
BLOCK ACCEPT
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
kevin.hammond3WX4X
Try this....
FORM BLOCK
GET BLOCK $VarModel
BLOCK ACCEPT
Jason_McDaniel
This works. Thank you. 🙂
Jason_McDaniel
This works. I don't know why I thought I needed the FILEOPEN command there. Thank you. 🙂
urizenYHS3W
FILEOPEN raises the file browser and puts you into a state where PowerMill variables aren't known. I would recommend not using FILEOPEN FILESAVE when writing macros unless you really want the user to interact with the file system via the browser.
Jason_McDaniel
Good to know. Thank you.
