PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Problem with Macro to load triangle block definition
6 REPLIES 6
Jason_McDaniel
332 Views, 6 Replies
Hello. I'm not sure of the correct syntax I need to get this to work. I'm trying to write a macro to load an exported ViemMill model as block.
FORM BLOCK
EDIT BLOCKTYPE TRIANGLES
// Open Import Browser
STRING $VarModel = ''
$VarModel = FILESELECT "Please select a exported ViewMill state file"
// Load exported ViewMill state model as new Block
GET BLOCK FILEOPEN $VarModel
EDIT BLOCK COORDINATE WORLD
DRAW BLOCK
BLOCK ACCEPT
I'm getting the following error: "Unable to open block definition file '$VarModel' from line 10.
What am I doing wrong?
Thank you,
Jason
Labels (3)
6 REPLIES 6
iamcdn79
in reply to: Jason_McDaniel
Try
FORM BLOCK
GET BLOCK $VarModel
DRAW BLOCK
BLOCK ACCEPT
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Try this....
FORM BLOCK
GET BLOCK $VarModel
BLOCK ACCEPT
This works. Thank you. 🙂
Jason_McDaniel
in reply to: iamcdn79
This works. I don't know why I thought I needed the FILEOPEN command there. Thank you. 🙂
FILEOPEN raises the file browser and puts you into a state where PowerMill variables aren't known. I would recommend not using FILEOPEN FILESAVE when writing macros unless you really want the user to interact with the file system via the browser.
Good to know. Thank you.
Technology Administrators
