PowerMILL To Vericut getting start.
hx
hx
I want to learn some software operation for PowerMILL 2017 to Vericut.
Where can I get the getting started files?
To the best of my knowledge, there are no getting started files or online help documentation on how to use the Powermill to Vericut plugin.  If anyone knows differently please post it because I'd like to see it as well.  It is not even worth trying to use the plugin at the moment because it's not working.  There is another thread following this reported problem.  Powermill SP5 was recently released and still no fix for the plugin.   I've been waiting since SP1 for this fix.
hx
@Anonymous
If the Plugin is not work.
I can use the PowerMILL2Vericut 2013(64-bit) or 2014 to do the same things.
Can use give the tutorial fot eh PowerMILL2Verictu 2013 or 2014.
Hins Ho.
Yes you can use the older versions of the Powermill to Vericut interface and tutorials to get started, however just to let you know from what I've experienced the 2017 version is a lot different.  I've used the old version to create vericut project files from my Powermill file for a few years now and when I tried the 2017 plugin there were a lot options that I had no idea what the input should be.  That being said, the old version is simple and very easy to use  I don't think you'll have too much trouble getting it to work.  Best of luck.
