Powermill surface projection finishing. help
Message 1 of 10
Replies (9)
Message 2 of 10
That's a very broad question I'm afraid.
https://knowledge.autodesk.com/support/powermill/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/PWR...
^---- This is the most general to get you started.
You'll likely also want to look plane projection as well since they have alot of similarities.
Message 3 of 10
ksorbo6
What kind of toolpath are you trying to get in the end?  Is it meant to spiral around the entire object?
Message 4 of 10
Exactly I want to do that. It's like using a rotary strategy.
Message 5 of 10
ksorbo6
So you'd  have to create a dome-shaped surface, either inside or outside of the part, in whatever 3d program you have, and then import that in as a reference surface. But for this piece it seems like a point projection would work too - surface projection just gives you more precise control.
Then you'd maybe play with your tool axis settings. Lead/Lean -> Preview Frame Normal to have it stay perpendicular to the reference surface, or maybe towards line for a more simple rotary. Depends on what kind of machine this is.
Message 6 of 10
Chetan.Bankar
@Anonymous wrote:
Hi @Anonymous,
Welcome to Autodesk PowerMill forum community.
As rightly mentioned by @ksorbo6 you will need to create a cone or dome shape surface (In 3D CAD modelling software such as PowerShape) around the model to be machined. This surface can then be imported into PowerMill project as a Reference surface to be used in surface projection finishing.
Also you will need to set the workplane at the bottom center of the model with Z axis parallel to the side of the model about which you need a rotary toolpath.
I have found a video on youtube which will be of some help to you.
Thanks and Regards,
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 7 of 10
thanks everyone. But I still can not do it
This is the model to runThis is the model to runThis is the surface I createdThis is the surface I createdtoolpathtoolpath2.png3.png4.png5.png
Can anyone give me suggestions?Thank you
Message 8 of 10
You'll have to excuse the place holder models. I know yours has some undercuts and such that will be likely harder to get at.
In this case it sounds like you want a toolpath that starts at the top of the head and then spirals down the model. This is a very rare case where I would probably use Point Projection.
The other option  is to create a dome over the part and use a Surface Projection Finish with a U pattern Spiral. The dome you create is converted to a reference object and will not be machined, it's there just as a support for the model in general.
Message 9 of 10
ksorbo6
To get it to spiral, I *think* your reference surface needs to wrap around itself like in this picture, with the seam vertical. That I just made with a revolve command. And then also check "spiral" and use the right direction, U or V, like you see in ribble's picture
Message 10 of 10
Vì vậy, vấn đề là khá khó khăn. Bởi vì bề mặt là một bề mặt phức tạp
