PowerMill 2024.0 now available
clinton.perry
Alumni Alumni
Message 1 of 17
clinton.perry
PowerMill 2024.0 is being released today (May 10, 2023). Over the next few weeks, you will see PowerMill 2024 availability in your account. Please check your Autodesk Account or use the new Autodesk Access tool to see when your entitlement is available for download.
For more information about what's being delivered in PowerMill 2024, check out the following links:
We will also be sending emails in the coming days. These will be localized into English, German, French, Italian, Spanish, Japanese, Chinese, and Korean. As before, the emails will be sent to the named individual who is listed as the account manager for each customer account.
Replies (16)
Message 2 of 17
Mansari84.ma
With this Autodesk strategy for weak develop and slow progress and old method in every version of Powermill software compared to nx, hypermill, solidcam, etc., you should say goodbye to this software.
 after 227 years ! powermill 2250! (We finally managed to change the menus!!!
Message 3 of 17
glen_h
@clinton.perry
I just tried to install Powermill 2024.
From my Autodesk account, downloaded this: "Create_Installer_PWRMU_2024_English_WIN64.exe"
Which is just a downloader.
After it finished downloading the install package (incidentally it put the files wherever it pleased without asking), I chose the "show in folder option", Then I ran the "setup.exe" file as administrator.
At some point during the installation, it failed and gave me this error:
(same thing happened when trying to install Powershape Ultimate 2024)
Not sure if there was some other software component that has to be installed first?
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
Message 4 of 17
M_Hennig
It did work for me but it tossed it on my desktop where it took some digging to find.
Message 5 of 17
Benjamin.Br
Hello @glen_h. I'm sorry you're having this problem. Can you please contact Autodesk support for assistance: https://www.autodesk.co.uk/support/contact-support .
Benjamin Brereton
Director, Engineering
Message 6 of 17
glen_h
@Benjamin.Br
Sure no problem.
Message 7 of 17
glen_h
Big thanks to Goran from Autodesk Support Chat.
As per his instructions, I followed the steps in this article:
"Install Failed - Error 232" when installing AutoCAD LT or Revit LT (autodesk.com)
Then I was able to install Powermill Ultimate 2024 and Powershape Ultimate 2024 without issue.
Message 8 of 17
Always-Love-CNC
The flat surface finishing strategy does not have filter parameters, and small holes may break the tool, posing a safety hazard. It is recommended to add filter parameters!
Slaves of CNC
Message 9 of 17
TK.421
@clinton.perry  When is that awful splash screen gonna go away??? it ties up the whole monitor until powermill is done loading 30 seconds later!
the numbers never lie
Message 10 of 17
febrijosani22
Community Visitor
Community Visitor
wheres powermill? all i can found was fusion 360
Message 11 of 17
396993356
Hello Clinton Perry! High-precision machining strategies such as PowerMill 2024 open up additional blanks, lifting the tool back and forth between two similar boundaries. This extends the machining time, reduces unnecessary tool lifting only by manually arranging the sequence, manual arrangement programming takes a lot of time, and also increases the risk, dear Clinton Perry! Whether additional blanks can only be effective within the boundary.
Message 12 of 17
emilie.a
@396993356 I'm sorry our software is causing you difficulties. Is there any chance you could share the project file with us, either here or with your support team (for confidentiality) so that our development team could investigate the problem?
Emilie.A
Software Development Manager
Message 13 of 17
396993356
Thank you very much for Emily A's reply.
Message 14 of 17
396993356
Message 15 of 17
rafael.sansao
Your issue is being caused by the "Additional stock" of 7mm.
I changed it to 3mm and the toolpath looks good.
Rafael Sansão
OptiNC - www.optinc.tech
Message 16 of 17
Always-Love-CNC
7mm is for more safety! The main reason is that the jumping toolpath is not within the boundary.
Slaves of CNC
Message 17 of 17
396993356
设置2毫米一样会来回抬刀.如果抬刀能控制在边界范围以内会更完美
